turtle racing dragstart
Nya och gamla produkter
Re: turtle racing dragstart
Post by huSSe » 02 May 2011, 16:02
tur man inte var så snabb!
hade vart tråkigt att behöva skicka tbx
på engång.
Post by huSSe » 02 May 2011, 16:03
Burnout wrote:j****a redan problem :hammer:
den verkar jävlas mer än den originala.
den här jävlas innan man öppnat paketet :cheesy:
Post by Burnout » 02 May 2011, 16:06
Sk*t i, kan säg förlorade mina pengar :mad:
håller till vanligt cy starter!
Post by Burnout » 02 May 2011, 16:08
Ända jag har inte ens prova den Tr dargstart ännu i påser
jag kommer köra sk*t ur TR dragstart :twisted:
Post by huSSe » 02 May 2011, 16:12
Burnout wrote:Sk*t i, kan säg förlorade mina pengar :mad:
du ska skicka den till turtle, du får en ny då.
Post by Burnout » 02 May 2011, 16:15
Ja vet MEN jag orkar inte skicka tillbaka dit och tillbaka hit.... :hammer:
Post by huSSe » 02 May 2011, 16:17
If you have purchased a TR Pull Start please send it to me for a rework. I want to machine the inside of the housing to clear the rope better and less rubbing on the rope. You will get much better recoil too.
If you have a brand new still in package pull start I will replace it with a modded pull start so there will be an immediate turn around. If your pull start has been used I will machine yours and I will only have it for 1-3 days. All modded pull starts and pull starts made from now on will have a TR engraved on the inside of the housing to easily identify the modded housings. I will post a pic of the TR and it'splacement on the housing.
Please send to;
David Bowman
Turtle Racing
6373 Alcock Dr.
Sand Creek, Mi. 49279
For International customers, I have thought a lot about what to do and probably the best thing would be to send me a picture of your housing destroyed, put it in the vise and bend the edges or do something to destroy it and I will send you a replacement.
Send Picture, name and address to info@turtleracingproducts.com
I am sorry for the inconvenience, but we will always strive to provide you with the best product possible and I feel this mod will be well worth your time..
__________________
Post by Burnout » 02 May 2011, 16:23
jag ska skicka e-post till dom då
Post by S 500 R » 02 May 2011, 17:09
Men ni som köpt en behöver ju inte skicka tillbaka den i alla fall.
Post by Malte » 02 May 2011, 17:29
Finns en tråd på HBF om hur du moddar själv, jag klipper och klistar:
If you would like to Mod your TR pull Start yourself, here are some instructions.
First, remove handle while holding spool tight, after you have removed handle, let the spool SLOWLY unwind.
Remove screw under TR logo and carefully remove internals.
This is my pencil grinder and cylindrical carbide deburr, a dremel will also work fine. The debur bit is a double cut and easily available at fastener supply and a lot of home supply or automotive supply.
Carefully grind a flat between the 2 cut lines in the housing. Nothing critical or difficult here. Just make sure not to leave any sharp edges.
Should look something like this when done.
During reassembly, MAKE SURE the small hex lines up and is fully engaged before installing screw, once you are sure, install screw and tighten. I would suggest about 2 turns preload on the string then feed it through the hole and tie off the handle.
Post by Robban » 02 May 2011, 17:34
Burnout wrote:jag ska skicka e-post till dom då
Slå sönder den du har, Skicka bild på det till Dave så skickar han en ny? Hur enkelt som helst. Sen om Lusse skall göra samma sak så förslagsvis så tar ni bild på samma dragstart men kanske mer sönderslagen så har ni en extra?
Annars kan jag köpa den av dej Pontus. Bara skrika till
Post by Burnout » 02 May 2011, 17:58
Precis svar från TR!
Dom sa att jag ska slå sönder TR dragstart sen skicka bilder till dom!
Dom skicka nya TR Dragstart till mig!
Post by Robban » 02 May 2011, 18:33
Burnout wrote:Precis svar från TR!
Det stog juh precis så i det husse klistra in?
Post by Burnout » 02 May 2011, 18:37
Ändå jag har skicka e-post till dom :sunglasses:
Så jag vet nu bara slå sönder..... :hammer:
ps71
Post by ps71 » 02 May 2011, 18:46
Jeg tror du bare skal slå istykker huset og ikke innmaten sånn som jeg skjønte det.....
Hpi baja ss passe oppgradert
