Carson 1/6 Monstertruck CRT incl. Radio Controll System
Nyheter och erbjudanden från rc-car-online
Moderator: rc-car-online
rc-car-online
Post by rc-car-online » 29 Jan 2010, 12:52
This model is based on the proven Comanche monster truck, but features different body shell and wheels and an improved equipment.
Details:
- 1/6 scale
- 2WD rear wheel drive
- 4 mm aluminum chassis with countersunk screws
- alloy parts blue anodized
- double a-arm suspension front and rear
- camber, caster and toe-in adjustable in front, camber and caster in rear
- threaded shock bodies for easy adjustment of spring preload
- differential with spline drive shafts
- epoxy brake disks
- fuel tank (capacity 0,7 litres) with fuel filter and vent line
- rigid rc-plate with splash protected boxes for receiver and receiver battery
- side mounted rocker panels protect against dirt
- painted lexan body shell
- tires on chrome rims, mounted and glued
- protective cover for the primary gears and differential spur gear
- complete FM rc-system already installed
- failsafe module with engine stop (line breaker)
Technical data:
· length ca. 700 mm
· width ca. 460 mm
· height ca. 290 mm
· tire width 90 mm
· tire-Ø 160 mm
· engine Carson PT 23 cm³
Our Price: 477,77€
Link to the Onlineshop:
http://www.rc-car-online-shop.de/lshop, ... uck,,,.htm
Re: Carson 1/6 Monstertruck CRT incl. Radio Controll System
Post by S 500 R » 29 Jan 2010, 13:20
That is a nice price!! Might be something for those how want to try out large scale!
