winter tires, those who needs them
Suomipoika
Post by Suomipoika » 24 Oct 2012, 20:54
Ok homies...
How many you guys are stuggler winter and ice??
Well, here is how i do deal the ice and snow..
My tires were hostile mxt, but you can use also hostile mx and minipin tires and proline bowtie tires, well, these i have used.
First you need to drill hole on the tire, 4mm drill is good.
And DO drill the hole center of the knob..
Turn the tire up side donwn ,and start to drill the metal sheet screws in to the tire, with those holes you did drilled just before.
Be gently, low rpms.
http://www.youtube.com/watch?v=eu9e4p49 ... ture=g-upl
I used 13mm metal sheet screws.
In front in the middle i used only one and second know gets the screw.
On the rear, i used all the knobs, so there is in every know this very sharp screw.
And do remember, on the front tires do it as zigzag
This is the best way you can get the grip on the ice.. :rock2: :rock2: :rock2:
Re: winter tires, those who needs them
Post by Dave » 24 Oct 2012, 21:24
On pure ice nothing works properly unless its a 4wd car.....
I made almost the same, but I used the ones with drill-tip for metal since they are hardened, but they were far from hard enough anyway.
On packed snow in the other hand, this works great !
But so does Koldkutters ;)
Suomipoika
Post by Suomipoika » 01 Dec 2012, 18:10
Amazing grip on these tires...
Had fun until one rear tire did blow out..
Really bites the ice.
Video is straight from the ainuz, but you can see something..
One hand driving :dance:
Suomipoika
Post by Suomipoika » 02 Dec 2012, 14:15
Some more film material..
Deam snow did take the sharpest pleasure off this ice driving away.. :curse:
My oldest daughter was behind the lens :clap:
