Mielke Christmas Set 5201 airbox + 5090 Hurricame tuned pipe
Nyheter och erbjudanden från rc-car-online
Moderator: rc-car-online
rc-car-online
Post by rc-car-online » 01 Dec 2009, 10:21
Only limited quantities available.
Regular total price: € 307.- (Mielke airbox € 78.- Mielke Hurricane pipe € 229.-)
You save over € 57.-
A Christmas present for the largescale touring car driver who is into a combination of a very good airbox with a leading-edge tuned pipe system.
Only while supply lasts!
To Mielke Airbox 5090:
Complete set including airbox with reuseable foam filter element, billet aluminum venturi adapter with o-rings, filter oil and hardware.
New version with o-ring "locks" for better sealing and easier assembly, new venturi adapter to reduce fuel consumption. The new version venturi adapter is specifically designed for use on carbs without choke!
To Mielke Hurricane tuned pipe:
The new Mielke-Modelltechnik open-up-system for 1/5 touring cars, latest version with plug system for connecting manifold and pipe.
• latest design tuned muffler made out of aluminum
• with removeable maintenance cap – unique on the market
• a revolution: finally you can remove the carbon deposits from the muffler and restore full performance!
• remove 3 screws and take the cap off. Now you can clean the inside with the included brush
• low weight (approx. 320 g) due to the aluminum construction, approx. 90-100 g lighter than comparable systems
• high quality stainless steel manifold
• complete mounting hardware with carbon bracket included
• weight positioned on chassis height for balanced handling
• super smoothperformance over the complete rpm-range
• clears all other parts like hydraulic brakes for hasslefree installation
Complete exhaust system with manifold and installation hardware.
Our Price: 249,90 €
Link to the onlineshop:
http://www.rc-car-online-shop.de/cgi-bi ... tmas%20set
