Offer of the Week:HPI Baja 5B 2.0 RTR
Nyheter och erbjudanden från rc-car-online
Moderator: rc-car-online
rc-car-online
Post by rc-car-online » 20 Aug 2010, 09:10
Regular price: 1098 .- €
Offer of the month price: 888,88 €
The 5B 2.0 is the updated version of the well known predecessor.
The Baja 5B is a rear wheel drive 1/5th scale off-road buggy that is nearly 32" in length! Its design is revolutionary for large scale RC Cars following the style of classic Baja buggies with long suspension arms for great ground clearance and large suspension travel. The big size allows the Baja 5B to go where smaller buggies can't and makes the Baja 5B's driving experience as close as you can get to the real thing.
The Baja 5B is big, but coming as a "Ready To Run" car, and powered by standard petrol it can't be easier to get ready for action. Everything is included in the kit - 1. Preassembled Baja 5B chassis, 2. Prepainted Baja body shell, 3. Preinstalled high quality FM radio gear with built in fail safe, 6V receiverpack and charger. 4. Preinstalled massive 23cc petrol engine providing plenty of power. All you need to do is fill up with standard petrol and some oil, and off you go!
These are the most important updates compard to the previous version:
- The new engine fitted in the Baja 5B 2.0 features an updated cylinder that provides 10% extra power!
- The High Flow Muffler from the Baja 5T is a much larger capacity design than the old standard muffler, and is tuned to give you more horsepower on the track. It sounds fantastic, too!
- Formerly an option part, the high performance 8000 RPM Clutch from the Baja SS and 5T is used to give you more punch off the line. Lightweight clutch shoes and a strong heavy-duty spring are the integral parts of this unit, and you will feel the power out of the turns.
- VVC/HD Shock Absorbers
These are the same damper units that equip the Baja SS and Baja 5T, and are now standard parts for the 5B 2.0 - these are oil-filled, externally adjustable coilover shocks for fantastic performance and heavy-duty action! Thick shock shafts provide security from crashes, threaded shock bodies allow instant ride height changes, and the externally adjustable design is tailor-made for trackside tuning.
- New anodizing and body shell colors
Please note:
- Due to the massive amount of images that page takes some time to load
- Flash plug-in is required.
Specifications:
Chassis:
- Overall Length: 817mm
- Height: 255mm
- Width: Front 460mm / Rear 480mm
- Tire Track: Front 395mm / Rear 400mm
- Wheelbase: 570mm
- Ride height: 76mm
- Suspension travel: Front 95mm / Rear 100mm
- Weight: 9.6kg (21.3lb)
- Camber: Adjustable front with shims rear with screw
- Front caster: Adjustable with shim 22 / 25.5* / 29 degrees (* stock)
- Toe-in: Adjustable front with tie rod rear with shims 2 / 3* / 4 degree each side (* stock)
- Air craft aluminum 6061 T6 monocoque chassis
- Double wishbone suspension with adjustable roll center F/R
- Twin plate ventilated disk brake
- Drive system: HD metal gears with sealed gear box
- Diff: Torque control viscous with 4 pinon gears sealed diff case with silicone oil
- Wheel type: 3 pcs with high impact nylon material
Engine:
- 2 cycle piston valve gasoline engine
- Cooling system: Fan cooled
- Displacement: 23cc
- Fuel: Pre-mixed fuel, 25 (Gasoline) : 1 (High grade 2 cycle engine oil)
- Starter: Recoil Starter
Radio:
- FM radio system with fail safe system
- Steering servo: Hi torque water resistant 25kg.cm with Speed 0.16sec/60 degree
- Throttle servo: Hi torque water resistant 6kg.cm with Speed 0.16sec/60 degree
- Receiver battery: 6V rechargeable NiCad battery
Link to the onlineshop:
http://www.rc-car-online-shop.de/lshop, ... _02,,,.htm
