Carson C5 version RTR with rc-system Ford GT, painted body
Nyheter och erbjudanden från rc-car-online
Moderator: rc-car-online
rc-car-online
Post by rc-car-online » 30 Jul 2010, 09:26
The chassis is pre-installed. The FM rc-system with two servos, receiver and rx-battery pack is factory installed, a charger is also included.
Easy handling and the high usability of a gas engine make this a perfect model even for beginners. It needs a fuel mixture (1:25) available at any gas station. One tank filling suffices for approx. 40-45 minutes driving fun. The engine is started like a lawn-mower. Just pour in the gas - push the fuel pump 2 to 3 times - pull at the pull starter - and ready you are!! There is an off/on switch on the engine to turn it off.
Details:
- 1/5 scale
- 2WD rear wheel drive
- 4 mm aluminum chassis with countersunk screws
- fully ballraced
- tuned pipe exhaust
- Double a-arm suspension front and rear
- camber, caster and toe-in adjustable in front, camber and caster in rear.
- Threaded shock bodies for easy adjustment of spring preload
- rear stabilizer bar
- Differential with spline drive shafts
- Epoxy brake disk on the layshaft
- front disk brakes
- fuel tank (capacity 0,7 litres) with fuel filter and vent line
- rigid rc-plate with splash protected boxes for receiver and receiver battery
- tires mounted and glued
- factory painted flexible Lexan body shell with decals applied
- complete rc-system included
Technical data
length ca. 900 mm
width ca. 400 mm
wheelbase 535 mm
23 cm³ PT engine with pull-rope starter
rc-car-online
Re: Carson C5 version RTR with rc-system Ford GT, painted body
Post by rc-car-online » 30 Jul 2010, 09:38
Ops, im so sorry. i have forgotten the price and the link :))))
the price is: 499.- €
Link to the onlineshop:
http://www.rc-car-online-shop.de/cgi-bi ... mt_zeilen=
Post by S 500 R » 30 Jul 2010, 10:11
That one i just awesome looking!!!
