Offer of the Week: FG Monster Truck 4WD RTR
Nyheter och erbjudanden från rc-car-online
Moderator: rc-car-online
rc-car-online
Post by rc-car-online » 23 Jul 2010, 15:58
The successful Monster models by FG are now available with the approved FG 4-wheel drive. These Monster models convince by their variety, on the race track, in the back yard or just on a parking site. The 26ccm Zenoah engine provides sufficient power.
This model will thrill you! A lot of technology and FG quality at an affordable price. We deliver the 4WD Monster models as RTR models completely mounted with applied stickers including pistol grip radio control system, servos, batteries and charger. A decal set with writings for further decoration is enclosed in the delivery.
Length 720 mm
Width 510 mm
Height 360 mm
Wheelbase 500 mm
Equipment of the 1:6 Sportsline 4WD chassis:
Angled 4mm alloy chassis with countersunk borings at the bottom, 4-wheel belt drive, belt drive cover, differential gear at front and rear axle with hardened bevel gears, closed front axle housing, closed belt drive at the rear, adjustable double wishbones at front and rear axle, all driving parts and gearwheels made of case-hardened steel, adjustable servo saver, 4 adjustable oil-pressure shock absorbers, rear gear brake, alloy side plates, Monster tires glued on chrome-plated rims, polycarbonate body shell, decal set.
The model is equipped with a powerful 26ccm combustion engine with muffler and ready-for-use oiled air filter. The engine runs with normal 2-stroke petrol-oil mixture (available at every petrol station). The tank capacity of 0,7 litres enables you to run your model around 45 minutes. With the installed pull-start system the engine can be started without any difficulties.
The RTR version is delivered with assembled and preset radio control system, charger and rechargeable batteries.
The pictures may display the car with some optional items which are not included, like bed-mounted rollbar, lights, front bumper or mirrors. These items can be added in the drop down menus. Without selecting these options the body shell includes only the decal sheet for decoration.
Normal price: 959,90 €
Offer the month price: 811,11 €
Link to the onlineshop: http://www.rc-car-online-shop.de/lshop, ... _03,,,.htm
