OotW - Mammoth Supergrip für 1:6er und 1:5er Tires, 2 Pair
Nyheter och erbjudanden från rc-car-online
Moderator: rc-car-online
rc-car-online
Post by rc-car-online » 25 Jun 2010, 10:02
Offer of the Week
Mammoth Supergrip for 1/6 and 1/5 offroad cars
Parking lot / race tires for your offroad car.
Glued on genuine FG rims (rear tires using extension rings), with foam rubber inserts included. Rim has 18 mm square drive with reinforcement ring.
Please note: based on experience we recommend against using other manufacturers rims and extensions. Since the Mammoth tires provide very good grip the rim and the bonding must withstand high loads.
The Mammoth Supergrip is available in in the following compounds:
General recommendation:
The dirtier the track or the lower the ambient temperatures, the stickier (softer) the rear tires should be.
Hint regarding the front tires: 2WD cars should use them one or two grades harder then the rears. 4WD cars usually like the same compound all around.
Prices per unit:
Mammoth Supergrip: Pair
Front: 44,90 € - Rear: 49,90 €
Tire inserts Pair:
Front: 13,00 € - Rear13,00 €
FG rim pair:
Front: 14,90 € - Rear: 14,90 €
FG extension ring pair:
Front: --.-- € - Rear: 14,90 €
Mounting pair:
Front: 13,00 € - Rear: 13,00 €
Prices Total for the front: 85,80 €
and for the rear: 105,70 € / Set= 191,50 €
HT prices Total for the front: 82,70 €
For the rear: 86,90 € Set= 169,90 €
Introductory price:
One pair each front tires medium and rear tires soft
€ 99.99 instead of € 169.90
Of course, the softer the tire the higher the wear rate; and this applies to Mammoth Supergrip onroad tires as well.
The tires have a special onroad thread pattern but will still provide ideal traction after the pattern has been worn out.
Link to the Onlineshop:
http://www.rc-car-online-shop.de/lshop, ... 580,,,.htm
Re: OotW - Mammoth Supergrip für 1:6er und 1:5er Tires, 2 Pair
Post by huSSe » 25 Jun 2010, 12:42
nice! :thumbsup:
Post by J.A racing » 25 Jun 2010, 17:22
Coola däck :thumbsup:
