Allt om KRAKEN VEKTA.5
Re: Kraken "Dragon Slayer"
- Maximoo882
- Phone Number: 0722525603
Kommer att bli ett jäkla monster.
Re: Kraken
Känd info:
Bild utan kaross.
4X4 all around CVDs
Two iterations both are ARTRs fully assembled and come with our own tires:
a) W/motor with 2 Kraken Large Scale servos
b) No/motor with 2 Kraken Large Scale servos
and yes standard 24mm wheel hex, you can use your favorite tires but I think you will like our ATD (All Terrain Dominator) that comes with the ARTR.
DDM is making their monster Dominator pipe for it.
Yes it's a G320RC from DDM, awesome price, perfect motor for the chassis. Great all around power for general bashing and racing.
A 29CC works really good too which we would bundle with our ARTR from factory.
But for those who can afford it anything with more HP would only wake up this beast even more. We are currently testing with G340 9.75HP from Sean@OBR and it's amazing. However the reed case push the cage out a little bit on the carb side. Anything full mod without reed case would be great. Sean if you are listening we need a 10HP non reed motor
Full rear trailing arms, telescoping universal drive shaft, Solid Rear Axle (no plastic)
sub $2K, well below that. BTW guys..."DRAGON SLAYER" was just a joke if you can catch my drift - Aiming at China.
it's more or less size of the LOSI
All the parts you are looking at are almost 1/4 scale parts.
Bild utan kaross.
4X4 all around CVDs
Re: Kraken
Misstänkte att namnet hade med dragon Hammern att göra
Losi 71cc Rcmax
Skopod 62cc Kraken vekta 5
Outlaw hybrid 32cc
Losi 5b
HPi baja
Outlaw hybrid 32cc
Losi 5b
HPi baja
Re: Kraken
More is revealed today of the rear end. You can see part of the massive rear roll cage, the gas tank sits low for better LCG. The following parts are BILLET ALUMINUM (CNC) - Rear Solid Axle Housing/Diff Cover as well as Full Rear Trailing Arms.
It would me a MISTAKE to make the rear solid axle in plastic, firstly it got to look realistic and secondly it has to be SOLID. With the amount of HP people are going to put through this beast, plastic will eventually crack or distort.
Massive shock bodies are hard ANO with 8mm shaft. Upper links are aluminum. Our philosophy is that we want this Beast to bridge the gap between RC/Motorsport.
Re: Kraken
Det här är ju hårigt så man får skägg i ögonen ffs......
Re: Kraken
Dax att byta namn på tråden till "Allt om Kraken Vekta.5"? Eller ny tråd i annan del av forumet?
Re: Allt om KRAKEN VEKTA.5
Malte? Har du fått din än?
- KaptenMagnus
- Phone Number: 0709475583
Byggtråd hade varit trevligtMalte wrote:Dax att byta namn på tråden till "Allt om Kraken Vekta.5"? Eller ny tråd i annan del av forumet?
- KaptenMagnus
Jävlar va tråkig den verkar. Blir trångt att få till axelbots på den
