nu tänkte jag denna laddaren eventuellt till bruschless projektet. ska visst gå att ladda rikitgt snabbt.
inte farligt dyr heller.
Specs er som følger:
Selectable charge rates range 10mA to 40A
Continuous maximum output power rating, 1344W @ +26.35VDC input voltage, 612W @ +12VDC input voltage
Using +26.35VDC to +32VDC input, 1344W output will deliver full current rating (40A) over the full range of output voltage up to 33.6V
Industry's first "daisy-chainable" Safe Parallel adapters available to maximize available power potential. Safely connect virtually any number (2s-6s for any brand or 2s-8s Cellpro compatible) of equal cell count/capacity together in parallel; charge, discharge, cycle, or monitor on a single PowerLab 8 (v2) unit. These items are peripheral products, available separately or as part of Combo packages, not included as a part of the basic PowerLab 8 (v2) unit.
Smart power management allows customer to select between programmable input power sources. Using the Charge Control Software (CCS), choose from several templates to get you in the ballpark, then fine tune the settings. Available settings include power supply input current limit, input low voltage limit, regenerative discharge rate and voltage limit. PowerLab 8 (v2) stores 1 set-up for Power Supply and 1 set-up for Battery and asks for verification one time on start-up
PowerLab 8 (v2) supports charging through node wires only (automatic current limiting to 3A maximum) or node wires in combination with discharge wires (charge rate support up to 40A max)
Initiate charge, discharge, monitor, and multiple cycles at the PL8 or via remote control from the CCS. Graph all major operations when using CCS.
Open Architecture presets allow for customization of any User Preset including show/hide presets on unit, preset name editing, up to 100 parameters control how presets are displayed and charging/discharge/cycling parameters associated with particular batteries and/or charging strategies. Unit includes 25 user preset banks pre-loaded for most major battery type/chemistries, plus 50 library presets.
Environmentally friendly, industry first, regenerative discharge capability of up to 1344W. Unlike traditional methods of discharge, which deplete the output battery's energy in the form of heat across a transistor, regenerative discharge takes most of that energy and puts it back into the input battery. In other words, when you discharge your LiPo for storage, you will be re-charging your Lead Acid input battery. The total amount of power that you can achieve is limited only by the amount of current that your input battery can accept, or 1344W, whichever is lower.
PowerLab 8 (v2) is also equipped with a traditional, 100W internal discharge capability which is non-regenerative.
Twin cooling fan
Massive over-sized internal heat sink
10AWG silicon input power cable and heavy-duty, removable plier clips
Massive sendust core toroid capable of 60A continuous input current requirement for maximum output specifications
vad tror ni om denna laddaren Powerlab 8
- MrKnopfler
- Phone Number: 0705919847
Re: vad tror ni om denna laddaren Powerlab 8
Den där kommer att funka bra
- Lotus
- Phone Number: 0709998877
Den ger ju bara knappt 10A mer än den du har idag
Eller har du gett dig tusan på att ladda maxamps ackarna med max charge rate
