Allt om KRAKEN VEKTA.5
pm98
Phone Number: 0703483642
Re: Kraken "Dragon Slayer"
Post by pm98 » 15 Oct 2015, 22:59
Maximoo882
Phone Number: 0722525603
Post by Maximoo882 » 16 Oct 2015, 14:03
Kommer att bli ett jäkla monster.
Re: Kraken
Post by Malte » 16 Oct 2015, 14:42
Känd info:
Bild utan kaross.
4X4 all around CVDs
Two iterations both are ARTRs fully assembled and come with our own tires:
a) W/motor with 2 Kraken Large Scale servos
b) No/motor with 2 Kraken Large Scale servos
and yes standard 24mm wheel hex, you can use your favorite tires but I think you will like our ATD (All Terrain Dominator) that comes with the ARTR.
DDM is making their monster Dominator pipe for it.
Yes it's a G320RC from DDM, awesome price, perfect motor for the chassis. Great all around power for general bashing and racing.
A 29CC works really good too which we would bundle with our ARTR from factory.
But for those who can afford it anything with more HP would only wake up this beast even more. We are currently testing with G340 9.75HP from Sean@OBR and it's amazing. However the reed case push the cage out a little bit on the carb side. Anything full mod without reed case would be great. Sean if you are listening we need a 10HP non reed motor :-)
Full rear trailing arms, telescoping universal drive shaft, Solid Rear Axle (no plastic)
sub $2K, well below that. BTW guys..."DRAGON SLAYER" was just a joke if you can catch my drift - Aiming at China.
it's more or less size of the LOSI
All the parts you are looking at are almost 1/4 scale parts.
Andren
Phone Number: 0766120140
Re: Kraken
Post by Andren » 16 Oct 2015, 16:39
Misstänkte att namnet hade med dragon Hammern att göra
Losi 71cc Rcmax
Skopod 62cc Kraken vekta 5
Outlaw hybrid 32cc
Losi 5b
HPi baja
pm98
Post by pm98 » 17 Oct 2015, 22:03
Re: Kraken
Post by Malte » 19 Oct 2015, 19:59
More is revealed today of the rear end. You can see part of the massive rear roll cage, the gas tank sits low for better LCG. The following parts are BILLET ALUMINUM (CNC) - Rear Solid Axle Housing/Diff Cover as well as Full Rear Trailing Arms.
It would me a MISTAKE to make the rear solid axle in plastic, firstly it got to look realistic and secondly it has to be SOLID. With the amount of HP people are going to put through this beast, plastic will eventually crack or distort.
Massive shock bodies are hard ANO with 8mm shaft. Upper links are aluminum. Our philosophy is that we want this Beast to bridge the gap between RC/Motorsport.
Re: Kraken
Post by Dave » 19 Oct 2015, 20:46
Det här är ju hårigt så man får skägg i ögonen ffs......
Post by Dave » 02 Nov 2015, 05:48
Nu finns det film på aset också.....
Re: Kraken
Post by Malte » 02 Nov 2015, 10:17
Dax att byta namn på tråden till "Allt om Kraken Vekta.5"? Eller ny tråd i annan del av forumet?
Re: Allt om KRAKEN VEKTA.5
Post by Robban » 02 Nov 2015, 14:18
Malte? Har du fått din än?
ers
Post by ers » 02 Nov 2015, 15:27
Ser tung ut dock...
Skickat via Tapatalk
Mvh Anders
4WD
Post by KaptenMagnus » 02 Nov 2015, 15:42
Malte wrote:Dax att byta namn på tråden till "Allt om Kraken Vekta.5"? Eller ny tråd i annan del av forumet?
Byggtråd hade varit trevligt Image
pm98
Post by pm98 » 07 Nov 2015, 18:14
pm98
Post by pm98 » 09 Nov 2015, 20:30
Post by KaptenMagnus » 09 Nov 2015, 20:34
Jävlar va tråkig den verkar. Blir trångt att få till axelbots på den
