http://www.davesmotors.com/s.nl/c.88503 ... id.8787/.f
Okej, då var dom kanske gamlawaqr wrote:Har sett dom där. Riktigt läckra
Nja, har ju redan Turtles variant på Offroad Bajan. Dock kanske dom skulle sitta fint på Street Bajansideburn80 wrote:Okej, då var dom kanske gamlawaqr wrote:Har sett dom där. Riktigt läckra
Men dom var läckra som sagt.. Fundera du på att skaffa?
Ja, skulle ju sitta som en smäck på din street...waqr wrote: Nja, har ju redan Turtles variant på Offroad Bajan. Dock kanske dom skulle sitta fint på Street Bajan![]()
Får dock avvakta lite nu. Har just köpt en j*vla massa saker till Bajorna som är på väg hem och dessutom lagt ner en mindre förmögenhet på min 1:12 track![]()
Du då, sugen på att skaffa?
The part enhances camber gain, by adjusting the length of the upper rear arm we are able to increase or decrease the arc of the rear tire as it travels through its suspension motion. Increasing the camber gain allows the contact patch of the rear tire to stay more parallel to the surface than the stock set-up increasing traction throughout the turn. This allows you to pick up throttle earlier in the corner, or even drive through the corner, increasing the speed through the corner, lowering lap times.
"Carving Blocks" let you carve through the corners. Team Phatdad's new track tool, "Carving Blocks", they give you the sharper edge to whittle away at the competition! Racer developed, and competition tested.
