Tillkännagavs idag av HPI.
Bensin artikelnr. 160323
El/Flux artikelnr. 169324
Bilarna kommer som kit.
View this email in your browser
The Baja 5B is BACK as a Self Build Kit!
Dear Emanuel
HPI large scale fans, we have heard you! The ORIGINAL, AUTHENTIC, HPI Baja 5B is BACK and ready for you to build from the ground up! The HPI SBK collection of Self Build Kits grows with the addition of not just one, but TWO 1/5th scale HPI kits! Fans of large scale off-road RC will be super excited to build their own GAS- or FLUX-powered Baja 5B with these new Self Build Kits!
#160323 BAJA 5B GAS SBK
#160324 BAJA 5B FLUX SBK
The ULTIMATE HPI Self Build Kits!!
Build and own the legend! Experience the thrill and excitement of building a car which ends up being over 80cm (nearly 32 inches) long and weighing nearly 10kg (over 21 lb)! Just install your own electronics (and engine for the gas-powered version) as you build and you'll be ready for any adventure that comes your way!
When the HPI Baja 5B buggy was first introduced, large scale RC was very expensive and quite difficult for the average RC hobbyist to experience. Using highly durable parts and innovative design features, HPI brought large scale off-road to new enthusiasts and ushered in a new, BIGGER era of RC!
The HPI Baja 5B and 5B FLUX are both equipped with extra-big and super-tough suspension parts, featuring awesome HPI durability! With its expertly designed molded composite suspension plus extra-long adjustable HD shocks, and massive high impact nylon 3-piece beadlock wheels, the Baja 5B is ready for full-speed racing on any off-road circuit!
Great Baja 5B performance parts are included:
Front & Rear Sway Bars
Super Heavy Duty Drive Shafts #104966
One-Piece Rear Hub Carriers #104781
24mm Heavy Duty Front Hex Hubs #105612
FEATURES SUMMARY
Unassembled 1/5th scale Off-Road Buggy
Ready for your 23-32cc RC engine or 6S/8S LiPo electronics
Ready for your radio gear
Enclosed radio box
Baja desert racing body design specific to gas or Flux version
Adjustable HD shock absorbers
Monocoque chassis
Low CG for superior handling
Long travel suspension
Viscous torque oil-filled gear differential
All-terrain tires and beadlock wheels
Aluminum rear shock tower
Hard plastic skid plates
Adjustable rear wing
Quick access to all critical maintenance points
Dual bellcrank steering
Cam type servo saver
Hex socket hardware
Gunmetal anodizing
Full set of rubber-sealed ball bearings
Enclosed receiver box
Chassis Specifications
Overall Length 817mm
Height: 255mm
Width: Front - 460mm; Rear - 480mm
Tire Track (to center of tires): Front - 395mm; Rear - 400mm
Wheelbase: 570mm
Ride Height: 76mm
Suspension Travel: Front - 95mm; Rear - 100mm
Weight: 9.6kg (21.3lb)
Adjustable Camber: front - shims; rear - screw
Front caster: adjustable with shim 22 / 25.5* / 29 degrees (* stock)
Toe-in: Front adjustable with tie rod; Rear adjustable with inserts 0-4 degrees (3 degrees stock set-up)
Aircraft aluminum 6061 T6 monocoque chassis
Double wishbone suspension with adjustable roll center F/R
Drive system: HD metal gears with sealed gear box (8.382:1 gear ratio)
Differential: viscous torque control with 4 pinion gears; sealed diff case with silicone oil
Shock absorber: HD construction and threaded fully adjustable coilover springs
Wheel type: 3 pcs with high impact nylon material with inset heavy-duty metal hex hub
HPI Baja tillbaka nu. Som bensinare och Flux/Elbil
MCD XR5 MAX PRO
FG GT 2017
MCD XR5 MAX PRO
FG GT 2017
