Blackbone Losi 5ive T Gear System
Blackbone, manufacturer of quality steel gear sets for most brands of Largescale cars, are pleased to announce the release in the first week of February of their gear system for the Losi 5ive T.
The 5ive T gear system will be initially only released in a set (later in the month all parts will also be available separately) and the range of gearing options will expand over the coming months too.
Upon release 56 x 21 and 54 x 23 ratios will be available. The set will include a new 'machined from solid steel' clutch bell, pinion and spur gear. You will need to use your standard Losi 19T chassis inserts that came with your car.
Blackbone will be releasing separately later in the month the clutch bell and pinions (18, 19 and 20) separately which can be used with the standard 58T spur gear so you can get rid of the rubbish pressed steel, welded clutch bell that comes with the car!!! Also a full range of pinions will be released for use with the 56 and 54T spur gears to allow a whole range of gear ratios
större drev och från blackbone til losi
