Rovan Baja 5b "Rovdjuret"
Re: Rovan Baja 5b "Rovdjuret"
Så här skriver Turtle:
I will have install vids on my web site soon, but until then I have some helpful things to do.
1:The small bearings on the Lay Shaft will go in with a very light push fit till they get close to the end, they will look like they are seated but they are not, the last little bit is press fit.You can finish seating them one of 2 ways, put the plastic end cap in the left side and the seal in the right side and put the cases in the oven on about 200*, put the bearings in the freezer, after about 15 minutes the bearings will be ready to drop in and might need just a slight hit to seat them.
Or, you can put the cases on some wood and use the head of a screw, a wooden dowel or any other flat object and hammer to seat them. Keep in mind, on the left half with the plastic cap, you will need to make clearance in the wood for the cap to go in. If you put the 2 cases together and there is a gap between them, you do not have the bearings fully seated.
2: Once you have the 2 case halves assembled(use the 4-m4x15 SHCS), put the Differential in, put the rear cap on and install BUT DO NOT tighten the 6 (m4x12 SHCS) screws. Leave them loose. Install complete Transmission in vehicle, now install 4 flat head screws (stock screws that come out of your stock transmission) into bottom of transmission, once all screws are installed, you may now tighten all screws including on the end cap.
3:The m4x12 Button head screw and flat washer go in the boss on top of the transmission to hold the trans plate solid.
Jupp !
Lagren passade fint utan värme och kyla, men hushalvornas passform kändes inte 100%......
De främre halvorna gick ju knappt att få ihop även om det inte fanns något monterat innuti.....
Skumt som f-n. Mina halvor hade den där goa klickpassningen. Axialspelet på diffen kan inte varit mer än några tiondelar.Carbon-Dave wrote:Jupp !
Låter som du ska reklamera ditt hus!Carbon-Dave wrote:Jupp !
Blir nog svårt att reklamera ett -trots allt- fungerande TR hus.....
Är det nån som reklamerat nåt till TR och vet hur dom resonerar ?
Det är väl bara att testa.... du kan ju inte få mer än ett nej!Carbon-Dave wrote:![]()
Tror Turtle är rätt bra att lyssna på lite feedback, så Pm´a honom på HBF och förklara ditt problem. Så kan jag nog lova dig att det blir löst på ett smidigt sätt.
jag har oxå en på min 5t och den var det klick passform.
rivner allt alu så læmnar du in ¨på anodisering.
så får du en enhetlig færg i næstan vilken kulør som helst.
och det ær inte dyrt.
Mailade dem i morse, så får vi se vad som händer......
Idag fick jag svaret !
Färgen kan variera och inget dom kan påverka.
Det är inget fel på mitt hus och det kommer inte bli några problem alls att få isär det nästa gång. (trots att jag tillbringade 10 minuter första gången jag satte ihop halvorna för att få isär dem utan verktyg)
Glappet för diffen i sidled kommenterades inte alls i svaret jag fick, utan TR såg inget problem alls eftersom huset fungerar.
Jag avslutade mitt svar med att säga att det hade iallafall KÄNTS bättre om jag istället hade fått till svar att det var märkligt, och att det absolut inte ska vara så, men att de inte godkänner en retur på ett hus som fungerar.
Hade varit lättare att acceptera, än att få till svar att det inte är nåt fel på det jag fick.
Nästa gång växellådan plockas ner, ska det filmas och länken från YouTube ska jag skicka till TR.
Där ser man... man kanske borde vara lite mer tillmötesgående.
Turtle Racing kunde lätt ha gjort mig nöjd, trots att jag inte skulle få växelhuset utbytt.
Svaret kom ju från David Bowman himself, så det är ju ingen support-tomte med PMS som skrivit svaret.....
Nu fick jag ett svar till.....
Tydligen hade han inte läst tillräckligt noga angående att diffen glappade i sidled, och nu var det ett annat ljud i skällan kan jag säga.....
Nu har han fått en adress att skicka ett nytt hus till, och så får vi se om jag får nån adress att skicka tillbaka mitt "defekta" till eller inte....
Jag frågade om jag kunde få ett svart istället......
Vad bra!!! Det känndes inte som TR på något vis! Skönt att det löste sig!
