plz remove thanks very much!
- D&N racing
FG-irish team driver
Evo 2012- Fg leopard race 2- Elcon monster beetle-
Re: UPDATED FG EVO FOR 2011
Your link is broken! Cannot find the film!
- D&N racing
fg evo 10 model upgraded and updated for 2011 season
sorry i put wrong link.
fixed
Looks awesome man! What are the benefits with the ECU?
I wonder that too? Were can I find that ECU?sx3 wrote:Looks awesome man! What are the benefits with the ECU?
The engine is tuned and built by Ian Oddiefied, and the ECU is one of his masterpieces among other tuning parts. His homepage is http://www.oddified.com/index.php but there's not much info about the ECU there!S 500 R wrote:I wonder that too? Were can I find that ECU?sx3 wrote:Looks awesome man! What are the benefits with the ECU?
- D&N racing
the ecu is quite handy,it tells you the amount of time engine has been running
which is a very good feature,cause you can tell when it needs it's next servise! (ie-piston ring etc)
it records the hours run time.
also it is great for setting clutch ie-rpm of engine...its tells you what rpm clutch will engage at.
another feature is ignition timing,it alters it in so many maps,mine is set at maximum map 10
which gives you a great hp boost,some say 1bhp extra...
it saves fuel also running engine at its optimum setting.
and it also tells you the maximum rpm of your engine which is benifical for any man tuning the engine.
YES a very good product.
this is the latest mark 2 version.
dan
dan
Can you use this ECU on a other engine then a Odefied engine?
- D&N racing
yes as far as i know you can.
do you want me to ask for you and find out??
Yes pleas do that!
- D&N racing
no problem bud,e-mail sent awaiting response from ian oddie
Thank's man
The oddified parts are really awesome! Do you also have the Mag-diff with coils from Oddie?
Oddie haven't wrote the prices on his stuff om the homepage, so may I ask you what the Oddie engine and ECU cost?
And also if you have the mag-diff, what the price is on it!
Keep it up!
Keep it up!
- D&N racing
i am waiting on a a reply s500 so i will let you know as soon as i have news
sx3
no i don't use a harm mag diff,i hear they are good,but i use a modified fg 4plate diff,i sent this to english current champion david bowen to modify for me,so now that is fitted too for 2011.(fg quad locking diff)
yes the oddified parts are very good,his engines are very aggersive and pump out loads of power,mainly low down.
take note also of the clutch i got,tourex from michael mileke,it is a true masterpiece,carbon fiber pads which NEVER wear out so it is a none replacment piece.
it has 4 settings of engagment,which is quite cool actually.
i have mine set on phase 3 which comes in around 10500rpm
essential for racing.
i had a brand new zenoah only done 5-6race days at our club,i sent this engine to ian oddie and paid 170pounds to tune it up fully,so if you had to get complete engine add the 170 on top of price of new zenoah,not bad though.
also the ecu is 170pounds
uk courency
hope this helps
dan
sx3
uk courency
hope this helps
dan
- D&N racing
S500 R
if you are reading this ,i have got word back from ian oddie and the awnser to your following question :
can the mark 2 ecu be used in any engine other than an oddie engine?
awnser is YES!
it can used in any engine!
hope this helps.
dan
awnser is YES!
hope this helps.
dan
