Ny motor - RCMK CR300B
Re: Ny motor - RCMK CR300B
Post by huSSe » 07 Apr 2012, 17:44
undra när den första OBR portade motorn kommer?
ingen som kan meila o fråga?
Post by Malte » 18 Apr 2012, 21:33
Saxat ifrån HBF om motorn. Behöver absolut inte vara sanningen men det kanske kan vara en vägledning ändå.
Originally Posted by Sayyaaf
Well, I just tested this engine. A nice start for beginners, but definitly not an alternative to any High performance engines offered by builders. I put it back to back in a 5T, one has 2 year old 30.5 full mod and the new RCMK, it is no match for the full mod. Full mod will eat it alive any time any where, and with flywheel and all, full mod still revs higher.
Post by Malte » 19 Apr 2012, 14:33
Mera info ifrån Bruce/Gizmo:
Guys i have been very busy and had no time to test this new Cr300B. We used 2 baja's both have the same everything. one has a stock zenoah 290 and both had 17/57 gears , Rear Dom pipe. now we have found that the Cr300B had good mid range and good top end. But in drag race with stock zen 290 we see that the CR290 is a little faster but not much.As i always say there is not 7Hp engines IMO. I have removed the Hp #'s on my website.But i will say that the CR300B bottom end is by far the nicest set up i have seen.You would be very happy with it.But if you want a bullet proof engine this is great one to have. The cyls have a lot of mods you can do to them also. Sorry for not posting sooner.
Så lite vassare än en zen 290 men långt ifrån 7hk tydligen!
Post by Dave » 19 Apr 2012, 16:57
Bruce/Gizmo wrote:As i always say there is not 7Hp engines IMO. I have removed the Hp #'s on my website.But i will say that the CR300B bottom end is by far the nicest set up i have seen.You would be very happy with it.But if you want a bullet proof engine this is great one to have. The cyls have a lot of mods you can do to them also.
Honom skulle man kanske snacka med lite......verkar ju vara en vettig och jordnära snubbe !
Post by Malte » 04 Jul 2012, 06:35
Eftersom V1 av denna motor kanske inte var så testad innan den släpptes och flertalet fick problem med den så är V2 ute nu.
Ser ut som det både kan komma in och ut lite mera luft nu!
Post by Rallyfinnen » 04 Jul 2012, 08:46
Som det ser ut så lär det bli fler varianter innan kylningen fungerar..
Man har sett det så många gånger i jobbet osv, ett konstruktionsfel som ska åtgärdas, men man väljer inte den rätta lösningen på problemet (omkonstruktion) för det blir för dyrt med nya verktyg osv, utan man lägger ett billigt 'plåster' som man hoppas ska fungera, men ingen egentligen tror på. Ungefär så såg detta ut. Fläkten blåser lite på cylinderfoten typ.. Kylningen behövs mest vid toppen och utblåset.
Post by huSSe » 04 Jul 2012, 09:50
jo det är ju där det är som varmast.
hoppet över ger en aldrig :hammer:
jebogren
Post by jebogren » 04 Jul 2012, 19:39
Finns som full mod nu också på gizmo
Users browsing this forum: Bing [Bot] and 3 guests
