FG Baja Buggy complete with radio control with painted body
Nyheter och erbjudanden från rc-car-online
Moderator: rc-car-online
rc-car-online
Post by rc-car-online » 12 Feb 2010, 11:35
This special offer ends on march 15th 2010!
Normal price: 955,90€ in this configuration.
RTR - version with painted body.
You are looking for good quality at a reasonable price? Then the new FG Baja Buggy 4WD is your best choice. Fourwheel drive, completely mounted ready-todrive, combined with the open Baja bodyshell and the metal roll cage as well as the gigantic Off-Road rims with low-profile knobbed tires.
This gives the Baja Buggy an unmistakable striking look and means pure driving fun.
Equipped with a 26ccm engine the Baja is aggressive and also a tremendous jumper. Additionally the 4WD grants the
model the maximum driving power and highest fun factor on every surface and in all curves.
Equipment of the 1:6 FG Baja Buggy 4WD/RTR:
Angled 4mm alloy chassis, completely covered belt drive, 2 differential gears at front and rear axle with hardened bevel gearwheels, closed front axle housing, front bumper, double wishbones at front and rear axle, gear brake, adjustable right/left thread rods at the track rods and at the front and rear wishbones, fully ball-raced, 4 large-volume oil-pressure shock absorbers, alloy side rails, rc plate, receiver box.
The alloy side rails protect the rc parts, tank a.s.o. as far as possible against dirt. The 2-piece body shell is made of polycarbonate. The giant low-profile knobbed tires are glued on
white rims. Front and rear axle are equipped with wide-base tires.
The model is equipped with a powerful 26ccm combustion engine with ready-for-use oiled air
filter. The engine runs with normal 2-stroke petrol-oil mixture (available at every petrol station). The tank filling of 0,7 litres enables you to run your model around 45 minutes. With the installed pull-start system the engine can be started without any difficulties.
The RTR version is delivered with assembled and preset radio control system, charger and
rechargeable batteries. To complete the non- RTR version all popular servos and radio control systems are suitable.
Normal price in this configuration: 955.90 €
Our Price is: 811.11 €
Link to the onlineshop:
http://www.rc-car-online-shop.de/lshop, ... bot,,,.htm" onclick="window.open(this.href);return false;
Re: FG Baja Buggy complete with radio control with painted body
Post by S 500 R » 12 Feb 2010, 11:38
Good deal :thumbsup:
rc-car-online
Post by rc-car-online » 12 Feb 2010, 15:58
Thank you :)
kjell
Phone Number: 0702465186
Post by kjell » 02 Sep 2012, 18:49
rc-car-online wrote:Thank you :)
hello i have this rc car,and it runs great... :lol2:
