68040R FG Baja Buggy 4WD RTR - 1pce. Offer 11/09
Posted: 20 Nov 2009, 17:27
Regular price from FG 990€
End of the offer november 30th
You are looking for good quality at a reasonable price? Then the new FG Baja Buggy 4WD is your best choice. Fourwheel drive, completely mounted ready-todrive, combined with the open Baja bodyshell and the metal roll cage as well as the gigantic Off-Road rims with low-profile knobbed tires.
This gives the Baja Buggy an unmistakable striking look and means pure driving fun.
Equipped with a 26ccm engine the Baja is aggressive and also a tremendous jumper. Additionally the 4WD grants the model the maximum driving power and highest fun factor on every surface and in all curves.
Equipment of the 1:6 FG Baja Buggy 4WD/RTR:
Angled 4mm alloy chassis, completely covered belt drive, 2 differential gears at front and rear axle with hardened bevel gearwheels, closed front axle housing, front bumper, double wishbones at front and rear axle, gear brake, adjustable right/left thread rods at the track rods and at the front and rear wishbones, fully ball-raced, 4 large-volume oil-pressure shock absorbers, alloy side rails, rc plate, receiver box.
The alloy side rails protect the rc parts, tank a.s.o. as far as possible against dirt. The 2-piece body shell is made of polycarbonate. The giant low-profile knobbed tires are glued on
white rims. Front and rear axle are equipped with wide-base tires.
The model is equipped with a powerful 26ccm combustion engine with ready-for-use oiled air
filter. The engine runs with normal 2-stroke petrol-oil mixture (available at every petrol station). The tank filling of 0,7 litres enables you to run your model around 45 minutes. With the installed pull-start system the engine can be started without any difficulties.
The RTR version is delivered with assembled and preset radio control system, charger and
Please note: the radio plate is designed to accept a 805-sized servo (case length 65 mm). For installation of a Rhino (case length 58 mm) or a similar sized servo you need to order radioplate 68241 separately.
Our price: 759,99 €
Link to the onlineshop:
http://www.rc-car-online-shop.de/lshop, ... adm,,,.htm
