Page 1 of 1
Offer of the Week: Mammoth offroad tires extra wide
Posted: 23 Apr 2010, 14:11
by rc-car-online
Regular price: 99,90€
Extra wide tire mounted and glued on genuine 1/6 scale FG buggy rims 6105/01 with extension ring!
Diameter 165 mm, width 80 mm. Fits all FG and Carson largescale cars, may fit other cars with 18 mm wheel squares as well.
HPI Baja 5 cars can also use these tires when equipped with special adapters.
Available in three different compounds:
soft
medium
hard
Unit price:
- Mammoth tires extra wide: € 47.20 / pair
- Mammoth inserts extra wide: € 9.90 / pair
- genuine FG wide track rims 6105/01: € 14.90 / pair
- genuine FG rim extension rings 6436: € 14.90 / pair
- mounting + glueing rims / extensions / inserts / tires: € 13.00
Total: € 99.90
Priced per pair.
We have tried various rubber / tire compounds for several months on various forms of terrain, etc..
The Mammoth brings, due to its quite strong and large pins and the extreme width of the tire, especially on hard and low grip surfaces a high traction!
The Mammoth is available in soft, medium and hard!
The rule is: the harder the ground the softer the tire compound.
Where other tires spin helplessly the Mammoth provides serious traction.
With few exceptions, the Mammoth is usually for the rear axle only.
The disadvantage of Mammoth tires:
Because of their extreme width they need to be mounted on FG wheels with extension rings and wide tire inserts (same as for the FG wide slicks), which is a labor intensive job.
From experience, we must strongly recommend against using rims from another manufacturer in combination with extension rings. Due to the before mentioned traction no other rim has been up to the task!
Broken rims and torn squares were the result.
However, the original FG-rim lasts without problems!
Our offer of the week price: 49,90 €
Link to the onlineshop:
http://www.rc-car-online-shop.de/lshop, ... _16,,,.htm
