Yes
Convert it
Allt om KRAKEN VEKTA.5
Re: Allt om KRAKEN VEKTA.5
Looks really nice!! And im with S 500, don't convert it, that machine needs to scream!
Skickat från min Nexus 4 via Tapatalk
HPI Baja 5b
Good choise
När kan man köpa dessa i Sverige?
Baja 5T OBR 30,5 VRC BigBore
Baja 5T G320 Dominator
3PM-X
3PM-X
- KaptenMagnus
- Phone Number: 0709475583
Du kan höra med tex Rc maffian så kan Jens säkert ta hem till diggcbossen wrote:När kan man köpa dessa i Sverige?
Det är nog ingen handlare som har dom i lager utan det blir beställningsvara
Started the conversion with the Wheelman Designz Conversion kit:
http://www.davesmotors.com/WheelMan-Des ... kta-5.html
Setup will be as follows:
TMM 40063-3 for Cars X2-SERIES (ordered, being build)
ON/OFF switch
WP version (increased protection against water)
design with active FAN cooling (2 × FAN)
power conductors 10.0 mm2
set of external capacitors
MP JET 1.8mm (recommended for integrated AntiSpark)
connector 8.0mm (5x)
please solder these connectors to controller
Castle Creations 2028 800KV brushless motor.
2 X 9500MAH 75C 5S lipo
2 X 7600MAH 70C 4S lipo
Speed is not what I aim for, I just need to find the sweet spot with this setup.
Working on the Vekta is very straight forward and it has been the best RC vehicle I had to work with hands down. One of the things is though that they can be heavy on the loctite, but it worked out fine.
Installing the brushless setup is thanks to this kit incredibly easy, and it beasically removes the need for relatively heavy mods to get to brushless on the Vekta.5
Came back from the States yesterday morning and wanted to directly build this thing in. Who can blame a fanatic?
Updates will follow, need to wait 2 weeks for the ESC, but we are patient...
ON/OFF switch
So you did change your mind and it wasn't run over......... but i already knew that
Losi 71cc Rcmax
Skopod 62cc Kraken vekta 5
Outlaw hybrid 32cc
Losi 5b
HPi baja
Outlaw hybrid 32cc
Losi 5b
HPi baja
