Det här kan vara bland det mest spännande på länge inom largescale offroad!
Trots att det är LiPo's inblandade är till och med undertecknad intresserad den här gången!
NEW Losi Promoto MX
1/4 Scale Motorcycle RTR
An RC motorcycle that looks and performs just like a real dirt bike? Let’s ride!
Price: $549.99 without battery and charger
$599.99 with battery and charger
Orders start shipping from 07/07
TECHNOLOGY
_ New Spectrum MS6X stabilizing technology to improve balance and control
_ Drive modes give best results for dirt, street or wheelie action with a switch!
_ Flywheel unit with gyroscopic force to greatly improve stability
REALISM
_ Compact design keeps scale look of a real motorcycle
_ Realistic yet durable rider with fabric racewear
_ Officially Licensed Dunlop Geomax MX53 Tires
_ FXR or Pro Circuit Graphics for genuine replica look
_ Body panels with bright colors wrapped in Officially Licensed designs
DURABILITY
_ Front crash structure with protected fork tubes
_ Rear fender pivots away and nylon bumper increases durability
_ Twin plate chassis adds realism, rigidity and durability
SUSPENSION
_ Rising rate rear suspension where damping becomes firmer in up travel
_ Front fork design combines form and function
_ Head angle has been rigorously tested for optimal handling
POWERTRAIN
_ Brushless power system means 40mph+ speeds
_ Front cable-driven disc brake drastically reduces stopping distances
_ Realistic chain drive with steel links on steel and aluminium sprockets
SPECIFICATIONS
Length: 20.2 in (512mm)
Width: 10.8 in (274mm)
Height: 17.3 in (439mm)
Weight: 123.5 oz (3500g)
Ground Clearance: 2.9 in (73mm)
Wheelbase: 13.9 in (352mm)
Chassis: 3mm Aluminum Plate
Suspension: Front Fork, Rising Rate Rear
Shock Type: 16mm Big Bore Aluminum Shock
Wheel Diameter: Front - 4.9 in (124mm), Rear - 4.5 in (115.5mm)
Radio: Spektrum DX3PM 3-Channel
Brakes: Front - Cable Driven Piston/Caliper/Rotor, Rear - Motor Braking
For more information, visit Losi.com
Race. Inspired.
#Losi #LosiRC #LosiRaceInspired #PromotoMX #LosiPromotoMX #ProCircuit #ProCircuitRaceTeam #ProCircuitMX @PCraceteam @ProCircuit78 @FXRmoto #FXRMX #FXR #FXRracing @FXRmotoeurope #JeremyMartin @JeremyMartin6 #SuperCross @supercrosslive @FOXracing #FoxRacing #FoxMoto @FoxMoto
Losi bygger 1/4 Motocross!
Re: Losi bygger 1/4 Motocross!
Fan, det är en stor grej...Det värkar vara en kul sak. Eller hoj.
Ja, den här ser skitkul ut!
Mycket större än jag trodde med!
Kommer förhoppningsvis under Augusti, väntar otåligt kan man lungnt säga...
